gzip compression is not enabled for a domain in Plesk, when nginx is enabled
7 comments
    Khang Tran
    In my case, Smart static files processing is checked but it's not allowed to change, why is it?
    Anna Morozyuk
    Hello @Khang Tran,
    That is because Proxy Mode is disabled, and thus domain is using nginx only not using Apache at all.
    If you want Apache gzip compression to be used - enable proxy mode.
    Otherwise, enable compression for nginx: How to enable gzip compression in nginx on a Plesk server.
    Kingsley Felix
    Can i disable Smart static files processing and Serve static files directly by nginx but still use Nginx caching under wordpress tool kit?
    Maxim Krasikov
    Hello @iamkingsleyf !
    Yes, you can disable options Smart static files processing and Serve static files directly by nginx but keep Enable nginx caching option enabled.
    Kingsley Felix
    alright thanks
    Jorge Salazar
    Hi @Kuzma Ivanov
    Why does the recommended way is to Enable gzip compression directly in Nginx?
    What advantage would have one over the other?
    Alexandr Nikolaenko
    Hello @Jorge
    In this way, compression will be enabled for both nginx and Apache web servers. And enabled options Smart static files processing and Serve static files directly by nginx continue to increase server response time, because requests are not proxied to Apache, but handled by nginx directly.
