Optimization test tools show that gzip compression is not enabled for a domain, when nginx is enabled
5 comments
    Kingsley Felix
    Can i disable Smart static files processing and Serve static files directly by nginx but still use Nginx caching under wordpress tool kit?
    Khang Tran
    In my case, Smart static files processing is checked but it's not allowed to change, why is it?
    Anna Morozyuk
    Hello @Khang Tran,
    That is because Proxy Mode is disabled, and thus domain is using nginx only not using Apache at all.
    If you want Apache gzip compression to be used - enable proxy mode.
    Otherwise, enable compression for nginx: How to enable gzip compression in nginx on a Plesk server.
    Maxim Krasikov
    Hello @iamkingsleyf !
    Yes, you can disable options Smart static files processing and Serve static files directly by nginx but keep Enable nginx caching option enabled.
    Kingsley Felix
    alright thanks
