Optimization test tools show that gzip compression is not enabled for a domain, when nginx is enabled
5 comments
    Khang Tran
    In my case, Smart static files processing is checked but it's not allowed to change, why is it?
    Anna Morozyuk
    Hello @Khang Tran,
    That is because Proxy Mode is disabled, and thus domain is using nginx only not using Apache at all.
    If you want Apache gzip compression to be used - enable proxy mode.
    Otherwise, enable compression for nginx: How to enable gzip compression in nginx on a Plesk server.
    Kingsley Felix
    Can i disable Smart static files processing and Serve static files directly by nginx but still use Nginx caching under wordpress tool kit?
    Maxim Krasikov
    Hello @iamkingsleyf !
    Yes, you can disable options Smart static files processing and Serve static files directly by nginx but keep Enable nginx caching option enabled.
    Kingsley Felix
    alright thanks
