Websites are not accessible after website settings are updated via Plesk: 502 Bad Gateway
4 comments
    tomaz
    Does this mean that changes for Apache will be applied only every 600 seconds?
    Ivan Postnikov
    Hello @tomaz,
    Yes, changes take effect only after the restart of Apache.
    Please, note that 600 seconds is an example value.
    Paul Hume
    After your recent maintenance my website has stopped working, how do I proceed?
    Ivan Postnikov
    Hello Paul Hume
    Please, could you clarify, what do you mean by maintenance? Was it Plesk update?
    What error is displayed?
    The quickest way to have the issue resolved is to submit a support request to Plesk Technical Support or to our partner depending on where Plesk license was purchased.
