kb: bug
ABT: Group A
- Plesk Onyx
KernelCare extension was used and then deleted. Now, the following errors are received via email:
PLESK_INFO: /bin/sh: 1: /usr/bin/kcarectl: not found
KernelCare extension cron task was not removed.
This is KernelCare extension issue with ID #EXTCERT-200 which was fixed in KernelCare 1.2.
Update the extension at Plesk > Extensions
As a workaround, remove the following file manually:
# rm -f /etc/cron.d/kcare-cron*
2 comments
I'm pretty new and not really experienced in server management. Can you please also provide the information where to drop the suggested command line?
I connected to my server via putty. After logging in, I entered the command line but that had no effect and I still get mailed that error several times a day.
Thx for help.
BR, Max
@Markus Frank-Schagerl Please run the following command:
ll /etc/cron.d/kcare-cron.rpmsave
And send me output
