If you had already registered your account at MyPlesk.com/Plesk360/Platform360 please use one for login. Otherwise please re-register it using the same email address as your existing Zendesk login (support account). It’s essential that you use the same email address on our support center to ensure that your tickets stay attached to the same account.
How to allow/forbid customers/resellers edit PHP settings in Plesk
2 comments
    Thedalet11
    Even if i disable all that settings,
    when logged in as a reseller  and going to edit a service plan, i can still edit all php settings and aplly them to any subsctiption my reseller owned. how do i block reseller those access to edit php settigns from service plans?
    Alexey Lapshin
    Hello @Thedalet11,
    The issue that forbidden permissions available in Service Plan for reseller considered as #PPP-35238, however, the issue is a cosmetic bug since no matter if the option enabled or not, it is not possible to manage PHP settings for Subscriptions under a reseller
