- Plesk for Windows
How to allow/forbid customers/resellers to edit PHP settings in Plesk?
The following permissions allow customers/resellers to customize PHP settings in their control panel:
Note: They can be enabled on the subscription and/or service plan level.
- Hosting settings management
- Common PHP settings management
- PHP version and handler management
Find a suitable solution below.
Go to service plan permissions settings to grant/revoke permissions:
for Plesk customers: Service Plans > plan_name > Permissions tab.
for Plesk resellers: Service Plans > Reseller Plans tab > plan_name > Permissions tab.
Enable the following permissions to allow PHP management or disable to forbid:
- PHP version and handler management_
_
Click Update & Sync.
Note: Locked subscriptions (Marked with a blue lock in the Subscriptions menu) will not be synced.
In Plesk, go to Customers > customer_name > Subscriptions tab > subscription_name > Customize (under Account on the right).
On the Customizing Subscription page, switch to the Permissions tab and enable the following permissions to allow PHP management or disable to forbid:
Click Update & Lock to apply the changes.
Note: This subscription will no longer be synced with its service plan.
In Plesk, go to Resellers > reseller_name > Customize (under Resources on the right).
Note: This reseller will no longer be synced with its service plan.
Note: the feature to allow/forbid access to some particular PHP parameter (like open_basedir
) is yet to be implemented.
Take part in our product improvement and vote for this feature on Plesk UserVoice.
2 comments
Even if i disable all that settings,
when logged in as a reseller and going to edit a service plan, i can still edit all php settings and aplly them to any subsctiption my reseller owned. how do i block reseller those access to edit php settigns from service plans?
Hello @Thedalet11,
The issue that forbidden permissions available in Service Plan for reseller considered as #PPP-35238, however, the issue is a cosmetic bug since no matter if the option enabled or not, it is not possible to manage PHP settings for Subscriptions under a reseller
