How to create and restore backup using Dropbox Backup extension?
5 comments
    Maarten Machiels
    Hi, could you please specify how much extra free disk space is necessary to run a full server backup using the Dropbox Backup extension? As many people have pointed out, using the Dropbox backup on a per subscription basis with the login details of the sysadmin presents a security risk, as all backups of all subscriptions are visible to all Plesk accounts. I'd like to use the full server back-up as a workaround, but the backup keeps failing because there is not enough disk space. Please advise.
    Robert Asilbekov
    @Maarten Machiels
    The current version of Dropbox backup prior to uploading a backup to the cloud creating a usual backup and then upload it. So the recommendation same as if you are creating a full server backup.
    Maarten Machiels
    Hi Robert, thanks for your answer. If I understand you correctly this means that a full server back-up requires at least 50% of free space? So, if I would perform a full server back-up, all the data will be first backed up locally and then moved to Dropbox, yes? So imagine I have a server with 100GB disk space, of which 80GB is filled with data, a full server backup would never be able to complete. I would at least need a disk space of 160GB?
    Robert Asilbekov
    @Maarten Machiels
    1) Yes, when you perform a full server back-up all the data will be first backed up locally and then moved to Dropbox.
    2) Disk space depends on data compression ratio. In a case when you have 80Gb data, 80Gb free disk space should be sufficient to create full server backup. Dropbox backup I'd recommend creating a per-subscription backup.
    Maarten Machiels
    Hi Robert. Thanks for your in-depth answer. This is now a lot clearer. Performing the Dropbox back-up on a per subscription basis would be the most flexibel, but there's an issue still. If an administrator performs subscription-based Dropbox back-ups, the customer accounts can see all the back-ups that are stored in the Dropbox account of the administrator and can even download them. This is a security and privacy issue preventing us to use the Dropbox back-up at the moment. It's been discussed in detail here https://ext.plesk.com/packages/9f3b75b3-d04d-44fe-a8fa-7e2b1635c2e1-dropbox-backup#!. Hopefully this can be addressed soon, because it's a great back-up solution, though unusable at the moment.
