Is it possible to connect to private Github repositories using Plesk Git extension?
6 comments
    Marek Kaczanowicz
    Hi, the connection is successful, but the auto-deployment seems to be not working from bitbucket...
    When I press the PULL UPDATES button - all OK, however, if I Commit to bitbucket, waiting few minutes and the repository is not populated automatically.
    What can be the reason of this?
    Alexandr Redikultsev
    Hello, @Marek Kaczanowicz!
    In order to automate this process, web hooks should be used, see the following page for the details:
    https://docs.plesk.com/en-US/onyx/administrator-guide/website-management/git-support/using-remote-git-hosting.75848/#o76296
    Evangelos Sapountzis
    I am using this method mentioned here, but I am unable to connect. I always get the following error:
    Public key for the server at 'github.com' is already known in '/var/www/vhosts/new.domain.com/.ssh/git_known_hosts'.
    ssh: connect to host github.com port 49153: Connection timed out
    fatal: Could not read from remote repository.
    Please make sure you have the correct access rights
    and the repository exists.
    Even if I try changing the SSH port to the default 22, I keep getting similar errors.
    Any suggestions?
    Denis Bykov
    @Evangelos Sapountzis
    The cause of this behavior is not clear, but I can see that you have resolved it by deleting id_rsa, id_rsa.pub and known_hosts file from the .ssh folder, according to https://talk.plesk.com/threads/github-integration-errors-unable-to-pull-updates-from-the-remote-repository.354967/
    @... Yes, indeed. I managed to resolve it with the help of a Plesk support agent. And the solution is the one found on the link you posted.
    Christian Bonato
    For those who have problems to interact with their Github private repository,
    here's what worked for me (Plesk Obsidian 18.x).
    1. You don't need to create a SSH Key on Github.
    Instead, you're going to create a PAT (Personal Access Token) on Github.
    From your GitHub account, go to
    Settings =>
    Developer Settings (*it's at the very bottom of the sidenav as of 2022-09-02) =>
    Personal Access Tokens =>
    Generate New Token (Give your password) =>
    Fillup the form (*see screencap below. Of course the comment is what you desire. For permissions, I checked 'repo' globally, I don't think you'll need any of the rest) =>
    click Generate token =>
    Copy the generated Token, it will be something like ghp_sFhFsSz52787sdTzMDreGRLjmks4Tzuzgthdvfsrta
    Make sure you copy-paste your token somewhere secure, as you won't be able to retrieve it if you lose it (you'll have to revoke it and create a new one).
    Your Token is now your "password"!
    2. Now go back to Plesk, go under your desired domain > Git,
    provide your github info (https path to repo, username)
    and copy your token inside the 'password' field.
    3. If you still have trouble in Plesk: once you have your Github Token,
    you'll have to SSH into your server,
    with a "System User" you create in Plesk,
    under your.domain > Web Hosting Access.
    Give this system user '/bin/bash' access (« Access to the server over SSH: »).
    Then, follow these StackOverflow instructions:
    Message "Support for password authentication was removed. Please use a personal access token instead."
    Of course, you'll need git installed on your server, but nowadays it usually already is.
    Open a SSH session, go inside your 'httpdocs' folder.
    You do not need to create a folder in 'httpdocs', git will create it named after your repo.
    Once you've successfully tested 'git pull', go back to Plesk (see step 2).
    Good luck!
