Is it possible to connect to private Github repositories using Plesk Git extension?
5 comments
    Marek Kaczanowicz
    Hi, the connection is successful, but the auto-deployment seems to be not working from bitbucket...
    When I press the PULL UPDATES button - all OK, however, if I Commit to bitbucket, waiting few minutes and the repository is not populated automatically.
    What can be the reason of this?
    Alexandr Redikultsev
    Hello, @Marek Kaczanowicz!
    In order to automate this process, web hooks should be used, see the following page for the details:
    https://docs.plesk.com/en-US/onyx/administrator-guide/website-management/git-support/using-remote-git-hosting.75848/#o76296
    Evangelos Sapountzis
    I am using this method mentioned here, but I am unable to connect. I always get the following error:
    Public key for the server at 'github.com' is already known in '/var/www/vhosts/new.domain.com/.ssh/git_known_hosts'.
    ssh: connect to host github.com port 49153: Connection timed out
    fatal: Could not read from remote repository.
    Please make sure you have the correct access rights
    and the repository exists.
    Even if I try changing the SSH port to the default 22, I keep getting similar errors.
    Any suggestions?
    Denis Bykov
    @Evangelos Sapountzis
    The cause of this behavior is not clear, but I can see that you have resolved it by deleting id_rsa, id_rsa.pub and known_hosts file from the .ssh folder, according to https://talk.plesk.com/threads/github-integration-errors-unable-to-pull-updates-from-the-remote-repository.354967/
    @... Yes, indeed. I managed to resolve it with the help of a Plesk support agent. And the solution is the one found on the link you posted.
