How to authenticate via HTTP when connecting to a remote Git repository in Plesk
4 comments
    Motaz Elshazly
    I have multiple repos related to the same domain, where one repo is for the main TLD, while the others are for subdomains of the domain, I am unable to sync the subdomains because it generates the same SSH key already added and used for main domain, how to fix that? thank you.
    Ivan Postnikov
    Hello Motaz Elshazly
    Due to the extension limitations, only one Git key can be used on the subscription.
    Vote for this feature on our UserVoice: Generate a deploy key per repo in the Git extension.
    Popular features are likely to be added in future updates.
    Felipe Santos (Edited )
    [ssh method]
    The issue start when you migrate subscriptions between Plesk instances. the keys from bit, comes togheter.
    and you are not able to synch files or recreate the key, we got a credentials login error, but its not the real issue.
    if i try to establish the same connection using another Plesk panel, works.
    Ivan Postnikov
    Hello Felipe Santos
    As I understand, you've already contacted support and it turned out to be this issue: https://support.plesk.com/hc/en-us/articles/360003256453
