If you had already registered your account at MyPlesk.com/Plesk360/Platform360 please use one for login. Otherwise please re-register it using the same email address as your existing Zendesk login (support account). It’s essential that you use the same email address on our support center to ensure that your tickets stay attached to the same account.
How to enable/disable automatic updates for WordPress plugins and themes in Plesk WordPress Toolkit
15 comments
    Ramsey Bashir
    Has there been any progress on this? Would be great to be able to set WordPress auto updates to minor and enable Plugins auto updates through the Plesk control panel.
    Alexandr Tumanov
    @Ramsey, the work on this feature is currently in progress. Hope that it will be released soon.
    1
    Bob Benson
    It appears that the Plesk Wordpress Toolkit DISABLES Wordpress's built-in automatic updates by adding the following to wp-config.php:
    <?php
    define('WP_AUTO_UPDATE_CORE', false);// This setting is required to make sure that WordPress updates can be properly managed in WordPress Toolkit. Remove this line if this WordPress instance is not managed by WordPress Toolkit anymore.
    Why is this done and can that change be reverted, in mass, for all affected Wordpress instances?
    If a Wordpress installation was configured for automatic updates, that setting should not be overridden by adding "WP_AUTO_UPDATE_CORE', false" to a customer's wp-config.php
    Help me to understand why Plesk would make that change to a customer's configuration.
    Ekaterina Babenko
    @Bob,
    Hi there!
    This is expected behavior. Once instance is attached to WordPress Toolkit, extension manages its update settings. In order to avoid any conflicts during updates, WordPress Toolkit disables WordPress native automatic updates tool. If you would like to use WordPress native tools, you can detach instance from WordPress Toolkit in WordPress > Instances > select your instance  > Detach.
    Bob Benson
    Thanks for the info.  I'd really like to have the viability, that Toolkit provides, into Wordpress instances on my server, including out-of-date core, plugin, and theme, notifications, without disabling Wordpress's native core update functionality.  I don't understand why the two cannot coexist.
    Anton Maslov
    @Bob, let's say Plesk Toolkit configured to install "minor changes" and Wordpress code "major changes" automatically. As a result setting from Toolkit won't work properly, because core always does a major upgrade.
    Also, could you please share the use-case why to keep both? Generally, Wordpress Toolkit do all the same but adds additional features like automatic backups before the upgrade and etc.
    Bob Benson
    @Anton, My customer's preferences should take priority.  If they have configured their own Wordpress installations with their preferences, those preferences should be respected (instead of Wordpress Toolkit disabling their configured auto-updates).  I, however, still want to see the state of the instances on the server and be able to mitigate issues, on demand, so I don't want to disable Wordpress Toolkit.
    Anton Maslov
    @Bob, why not then do all the preferences via Wordpress Toolkit including update options?
    Bob Benson
    @Anton, Because I would be overriding my customer's preferences that they have configured in Wordpress.  Many hosting customers don't ever log in to Plesk.  Once Wordpress is working, they only log in to Wordpress.
    Jannick Nijholt
    What's the update frequency of the WordPress Toolkit when Automatic Updates are enabled for a WordPress-website in the Wordpress Toolkit? And is it possible to edit the frequency?
    Does it for example check for new updates every night and automatically applies them?
    Julian Bonpland Mignaquy
    Hi Jannick Nijholt, yes you can do this in Tools & Settings > Scheduled Tasks. Look for the instances-auto-update.php task.
    Christian Lin
    Is there a way to filter out specific plugins from the automated list of upgrades? I have some conflictive plugins that need further backups before they are updated.
    1
    Anton Maslov
    Hi Christian, at this moment it can only update all. Though we might consider implementing such a possibility in future versions.
    1
    urniez
    This is a nice function, but having the website stay under maintenance mode and doesn't recover automatically just doesn't make any sense.
    Ryan Roskilly
    Is it possible to get a list of the updates applied automatically? At our company we usually need to keep a record of the previous versions of themes and plugins before an update to be able to rollback in case any of the updates break the website.
