How to chroot MySQL client for users ?
6 comments
    iamkingsleyf
    looks complicated
    Ivan Postnikov
    Hello @iamkingsleyf,
    Please, let me know which questions do you have when applying the solution from this article?
    iamkingsleyf
    you guys said its not recommended.
    Rico Rothenburger (Edited )
    That's not a good idea. Logged-in users can delete the file, which terminates the entire MySQL server.
    better: mount -o bind,ro /var/run/mysqld /var/www/vhosts/example.com/var/run/mysqld
    In general, however, the mount causes Plesk to delete the file and the MySQL server is no longer working. For example, if you delete the client, then all files will be deleted and also the mysqld.sock file.
    Is this workaround only for Plesk 12.5?
    Ivan Postnikov
    @iamkingsleyf, indeed, such actions are performed at your own risk.
    Bulat Tsydenov
    @Rico This workaround is applicable for all currently supported Plesk versions for Linux
