How to chroot MySQL client for users ?
8 comments
    Rico Rothenburger (Edited )
    That's not a good idea. Logged-in users can delete the file, which terminates the entire MySQL server.
    better: mount -o bind,ro /var/run/mysqld /var/www/vhosts/example.com/var/run/mysqld
    In general, however, the mount causes Plesk to delete the file and the MySQL server is no longer working. For example, if you delete the client, then all files will be deleted and also the mysqld.sock file.
    Is this workaround only for Plesk 12.5?
    Bulat Tsydenov
    @Rico This workaround is applicable for all currently supported Plesk versions for Linux
    Kingsley Felix
    looks complicated
    Ivan Postnikov
    Hello @iamkingsleyf,
    Please, let me know which questions do you have when applying the solution from this article?
    Kingsley Felix
    you guys said its not recommended.
    Ivan Postnikov
    @iamkingsleyf, indeed, such actions are performed at your own risk.
    Fabien F. Dubroca
    Hello Plesk Team,
    Trying to add mysql to a chrooted user on Plesk Obsidian but I'm getting a 404 on the update_chroot tool download.
    Can you please update the URL ?
    Thanks !
    Anton Maslov
    Hi Fabien, updated.
