kb: technical
ABT: Group A
This article describes how to subscribe to updates in articles and new articles.
Subscribe to all new articles in section
Plesk articles are divided into different sections. It was done to create an easier way to find the article knowing its relationship to the service. To subscribe to a section, navigate to Technical Questions and click on the required category. Each section has a description of what it contains.
Make sure that the selected category satisfy your needs according to the description and click Follow.
Select what are you interested in
Subscribe to one article
If it is required to subscribe to only one article, open needed article and click Follow button:
8 comments
Does the follow feature follow comments of an article?
Thanks.
@Tim, Yes
@Lev, OK! Good to know.
Why can't I decide to follow ALL new articles (instead of having to subscribe to every category)?
@b_p
Unfortunately it is limitation of Help Center in ZenDesk that is using as our Support Portal.
hay lắm
qem pode ajudar estalar plesk
aqui por favor
Jaime Silva it is very easy with just one click installer, see here. You you may order on of the cloud providers like Amazon/Google Cloud/DigitalOcean/Azure server with already installed Plesk.
