Unable to receive/send emails in Plesk with submission port (587) enabled: Connection concurrency limit exceeded
6 comments
    Del C
    It saved the file with that extension when I created the filter within Plesk - everything works though!
    Plesk 17.5.3 + CentOS 7
    RPMs:
    fail2ban-0.9.6-centos7.17031414.noarch
    plesk-fail2ban-configurator-17.5.3-cos7.build1705170314.17.noarch
    /etc/fail2ban/filter.d:
    -rw-r----- 1 root root 3241 Mar 14 2017 apache-auth.conf
    -rw-r----- 1 root root 2818 Mar 20 01:18 apache-badbots.conf
    -rw-r----- 1 root root 813 Mar 14 2017 apache-common.conf
    -rw-r----- 1 root root 1863 Mar 14 2017 common.conf
    drwxr-xr-x 2 root root 33 Nov 26 2017 ignorecommands
    -rw-r----- 1 root root 476 Mar 14 2017 plesk-courierlogin.conf
    -rw-r----- 1 root root 1481 Mar 14 2017 plesk-dovecot.conf
    -rw-r----- 1 root root 367 Mar 14 2017 plesk-horde.conf
    -rw-r----- 1 root root 650 Mar 14 2017 plesk-modsecurity.conf
    -rw-r----- 1 root root 529 Mar 14 2017 plesk-panel.conf
    -rw-r----- 1 root root 547 Mar 14 2017 plesk-qmail.conf
    -rw-r----- 1 root root 526 Mar 14 2017 plesk-roundcube.conf
    -rw-r----- 1 root root 666 Mar 14 2017 plesk-wordpress.conf
    -rw-r--r-- 1 root root 132 Mar 20 00:40 postfix-concurrency.local
    -rw-r----- 1 root root 482 Mar 14 2017 postfix-sasl.conf
    -rw-r----- 1 root root 1216 Mar 14 2017 proftpd.conf
    -rw-r----- 1 root root 1286 Mar 14 2017 recidive.conf
    -rw-r----- 1 root root 3160 Mar 14 2017 sshd.conf
    Konstantin Annikov
    @Del Corso
    I have checked this path in Debian, Ubuntu, CentOS (different versions of all OSes) and everywhere the file extension is the same (.conf).
    Please update us with OS and Plesk version you are using?
    Konstantin Annikov
    @Del Corso
    Thank you for your input. I have edited the article
    Miomir Besarabic
    Wrong: postconf smtpd_client_connection_count_limit = 100
    Correct: postconf smtpd_client_connection_count_limit=100
    Filter not accepted in Plesk Regex wrong.
    Robert Asilbekov
    @Miomir Besarabic  Thank you for the feedback, the article was fixed.
    Del C
    #7 should be
    fail2ban-regex /var/log/maillog /etc/fail2ban/filter.d/postfix-concurrency.local
