- Plesk Obsidian for Linux
- Plesk Obsidian for Windows
- Plesk for Windows
How to change default index type for a domain in Plesk?
Note: If the options described are not available in Plesk GUI, contact the server's administrator or the hosting support.
Note: By default, the index order sets *.html with more priority than the *.php files.
Click on a section to expand
Go to Domains > example.com > Apache & Nginx Settings > Check the option Enter custom value near Index files > Make all the required changes > Click OK to apply the changes:
Go to Domains > example.com > IIS Settings > Check the option Enter custom value near Default documents > Make all the required changes > Click OK to apply the changes:
To change the default document for all domains, use instructions available in the following article:
How to change the default index for all websites?
4 comments
Thank you
it work's
@Albert Stienen
Are you logged in as 'admin' user? It is not accessible for other Plesk users by design. Check https://support.plesk.com/hc/en-us/articles/360006905994 for details.
@Albert Stienen
You have a Windows server, and Plesk for Windows supports only IIS. Even if you installed Apache for Windows, Plesk will not recognize it and you should make any changes in its configuration manually (refer to https://support.plesk.com/hc/en-us/articles/115000063989-Does-Plesk-support-Apache-web-server-for-Windows- for more information). Plesk does not support such scenario, so make any changes on your own risk.
@Albert Stienen
Apache is not supported in Plesk for Windows. Instead, Plesk uses IIS web server. All our KB articles imply that Plesk has default configuration, e.g. IIS is used on Windows Plesk server, thus resolution for Windows contains steps on how to change default index type in IIS.
