If you had already registered your account at Plesk 360 (formerly known as My Plesk) please use one for login. Otherwise please re-register it using the same email address as your existing Zendesk login (support account). It’s essential that you use the same email address on our support center to ensure that your tickets stay attached to the same account.
plesk repair fs doesn't set correct owner inside httpdocs
14 comments
    Anzhelika Khapaknysh
    @Marc,
    Please try:
    # ./fix_permissions.sh
    I've updated the article. Thanks the notice!
    1
    Gergely Nagy
    @Alexandr
    Just had to use the script (i think for some cases it is better to use the script, instead of plesk repair) and found out, the script misses those files/folders inside  h.www_root if their name starts with a dot, or is does not restores the owner inside those folders. A small fix for me was to add an extra chown before doing the "psaserv restore" :
    chown -chR "${query[0]/ /}":psacln "${query[1]/ /}"/.[0-9a-zA-Z]*
    Jerry van Kranenburg
    Do not run this script, it will break your complete plesk installation!
    There is missing a /httpdocs at the end of the chown!
    "chown -R $user.psacln $VHOST_DIR/$domain/httpdocs"
    Otherwise also all logfiles and httpdocs and httpsdocs folder will change and all sites are down.
    Jason Schilling
    Doesn't correct dot files.
    Fouad Ahmed Fouad
    Thanks fro that script, it could help too much fixing permissions after migration from Cpanel, as permissions were corrupted and I was fixing it manually!
    Ivan Postnikov
    @Lenor
    Hello!
    Step 3 of the resolution was updated. The correct command is:
    # chmod +x fix.sh
    Alexander Tsmokalyuk
    @Jerry We have fixed the script. Thank you for reporting.
    Artyom Baranov
    @Gergely Nagy
    Thank you for noticing it!
    The script was updated: now all chown and chmod commands are executed by `find`. It's a little bit slower but should behave better in edge cases.
    Marc
    Have tried to use the script, but I cannot start it. Is it in the wrong folder?
    /root$ fix_permissions.sh
    -bash: Zeile 12: fix_permissions.sh: Befehl nicht gefunden
    Rob
    Is this working in Plesk Only now or do we still use this script ? a bit worried about using the script if it potentially touches any other web site.... Has Obsidian got this bug also ?
    Ivan Postnikov
    Hello Rob
    It's expected to be fixed during this quarter.
    Usually, script doesn't cause issues. However, I would suggest making a domain back up first to be safe.
    Also, keep in mind this warning:
    Warning: The following script sets the permissions for files inside the document root to 0644. In case there are files that require specific permissions, set them manually after executing the script, or restore a subscription backup.
    Lenor
    can run your chown on Cloudlinux:
    Error: chown: ungültiger Benutzer: „+x“
    Ivan Postnikov
    Hello @Jason,
    Could you, please, provide used OS, Plesk version and give an example of a file name, which was ignored by script from workaround.
    Marc
    Great help, thanks a lot. Problem is solved now :)
