How to check what process loads CPU, memory and other system resources in a period of time using atop utility?
Connect to the server via SSH
Install
atop
package:-
For RHEL/CentOS :
# yum install epel-release
# yum install atop
For Debian/Ubuntu :
# apt-get install atop
Start
atop
service to begin automatic system resources logging:# service atop start
Note: atop automatically creates a task in cron to begin logging at midnight if it is not running.
Adjust interval to the preferences:
For RHEL/CentOS :
Open the file
/etc/sysconfig/atop
and modify the line and set required interval (in seconds):
INTERVAL=60
For Debian/Ubuntu :
Open the file
/etc/init.d/atop
(or/etc/default/atop
, or/usr/share/atop/atop.daily
) and modify the line and set required interval (in seconds):
INTERVAL=60
Logged data might be opened via the command:
# atop -r /var/log/atop/atop_*****
Replace *** with actual log value (date). To move between intervals use arrow buttons or hotkeys t and Shift+T .
Note: For more information on available hotkeys refer to the atop manual page.
To disable atop use the following commands:
# mv /etc/cron.d/atop /root/atop
# service atop stop
1 comment
Please add such a functionality directly in the Advanced Monitoring extension. This would be a gamechanger :)!
