Plesk for Windows
Plesk for Linux
kb: how-to
ABT: Group A
- Plesk for Windows
What is Plesk autoinstaller and how to use it?
The Plesk autoinstaller, also known as Plesk installer, is a utility that allows to install, update and manage Plesk and its components.
For more details about the utility and how to use it, check the following KB articles:
2 comments
with "plesk installer" I've the image attached.
This procedure will allow me to perform a new installation, or even just upgrades of plesk and the elements?
Delete the existing plesk installation?
Thank you
Hello @Remigio,
The command "plesk installer" is available after Plek is installed.
The command may be used to update/upgrade Plesk or install/remove additional components.
Alternatively, the same actions may be done via GUI at Tools & Settings > Updates and Upgrades.
Plesk may be uninstalled using this instruction:
https://support.plesk.com/hc/en-us/articles/213907125-How-to-uninstall-Plesk-for-Linux
