What is Plesk installer and how to use it
2 comments
    Remigio Ruberto
    with "plesk installer" I've the image attached.
    This procedure will allow me to perform a new installation, or even just upgrades of plesk and the elements?
    Delete the existing plesk installation?
    Thank you
    Ivan Postnikov
    Hello @Remigio,
    The command "plesk installer" is available after Plek is installed.
    The command may be used to update/upgrade Plesk or install/remove additional components.
    Alternatively, the same actions may be done via GUI at Tools & Settings > Updates and Upgrades.
    Plesk may be uninstalled using this instruction:
    https://support.plesk.com/hc/en-us/articles/213907125-How-to-uninstall-Plesk-for-Linux
