A PrestaShop website installed via Plesk Applications fails to load with ERR_TOO_MANY_REDIRECTS
6 comments
    Carlos Ramos
    EXCELENT!!! THANKS!!!
    Olivier Kra
    Thanks, Very helpful.
    Laurent Ah Koon
    You saved my life and time!
    Hector Yoso Oki Suehara
    You need to login from the Backoffice, I was using the direct link from the plesk panel, and wasn't showing the Parameters nor the setup section.
    Just my 2 cents.
    Rahul K Shinde
    When I go to shop parameters > General  it again redirect  back to main site URL and end up in redirect loop.
    Other links works mostly ,just the shop parameters links are getting back.
    Rahul K Shinde
    Hmm, I see there were extra redirect parameters in the nginx settings. Hence it was redirecting Removed it now and its working.
