If you had already registered your account at Plesk 360 (formerly known as My Plesk) please use one for login. Otherwise please re-register it using the same email address as your existing Zendesk login (support account). It’s essential that you use the same email address on our support center to ensure that your tickets stay attached to the same account.
Execution of plesk repair mail utility fails: mailsrv_conf_init... not found
4 comments
    Martijn
    Following these instructions destroyed the `which` command completely.
    Any instructions on how to fix a missing /bin/which?
    Ivan Postnikov
    @Martijn
    Hello!
    The steps from the resolution recreate the link to /bin/which and there are not steps which may delete /bin/which.
    As a solution for your case, I can suggest installing "which". As an example, for CentOS the command will be:
    # yum install which
    De-velopment
    Hello,
    i get an error when I run the plesk repair mail command:
    ERR [util_exec] proc_close() failed ['/opt/psa/admin/bin/mchk'] with exit code [1
    Checking for: mail_dk_restore ... fail
    Errors occured in mail restore procedure
    Some utilities have exited with errors:
    /usr/lib/plesk-9.0/mail_dk_restore
    But I can not find anything in the log files and can not find any instructions in the forum.
    Yulia Plokhotnikova
    @De-velopment
    To get additional details about this error, it is required to check /var/log/plesk/panel.log. This error is indeed a new one, it was not reported previously, so it may be required to investigate it on a Plesk side. Consider submitting a support request to Plesk directly or to a reseller, depending on where the license was purchased.
