Is it possible to enable OCSP Stapling for a domain in Plesk?
8 comments
    Lars Doe
    "it has to be assigned an IP"
    This doesn't seem to be necessary. I also didn't put the "SSLUseStapling" into the domain's additional directives, but into the same file as the "SSLStaplingCache".
    Test with SNI (-servername) is crucial:
    echo QUIT | openssl s_client -connect example.com:443 -servername example.com -status 2> /dev/null | grep -A 17 'OCSP'
    Alexandr Redikultsev
    Hello @Lars Doe.
    Thank you very much for the feedback, the I have made some adjustments to the article based on it.
    Cyrill Fässler
    Dear Plesk Supporter
    This seems to be a tutorial for CentOS.
    We have servers that use Debian.
    What is the equivalent for " /etc/httpd/conf.d/ssl.conf " in the directory " /etc/apache2/conf.d/ " if there is no file ssl.conf ?
    Best regards
    Cyrill Fässler
    System Operator
    hosttech GmbH
    Hello @Cfaessler.
    As far as I can see, on Debian it should be /etc/apache2/mods-enabled/ssl.conf file.
    Andreas Schneider (Edited )
    Is "ssl_trusted_certificate /full/path/to/fullchain.pem;" really necessary?
    "The directory above is NOT needed to enable OCSP with Plesk if you have certificates setup for your domain."
    Source 1: https://community.letsencrypt.org/t/latest-le-extension-plesk-and-ocsp/31140/8
    Source 2: https://talk.plesk.com/threads/ocsp-stapling-with-letsencrypt-per-domain.343585/#post-828748
    I tested the configuration without the directory and slllabs.com says it works.
    Please update your tutorial if I'm right.
    Best regards
    Andreas
     Additional information: The Let's Encrypt Extension is installed in my Plesk...don't know if this makes a difference.
    1
    Hello, @Andreas Schneider!
    Thank you very much for your feedback.
    Yes, in current implementation of Plesk this part is not required.
    I have adjusted the article, thank you again for noticing it!
    Jan
    Do I have to revert my manual setup, from before?
    I have now installed the extension, but from the previous guide, this is my current config in nginx.conf:
    ssl_stapling on;
    ssl_stapling_verify on;
    ssl_trusted_certificate /etc/nginx/trustchain.pem;
    resolver 8.8.8.8 8.8.4.4 valid=300s;
    resolver_timeout 10s;
    Alexandr Nikolaenko
    Hello @Jan!
    Yes, it is required to remove all manually added entries regarding OSCP stapling before applying automated solution via "SSL It!" extension.
