If you had already registered your account at Plesk 360 (formerly known as My Plesk) please use one for login. Otherwise please re-register it using the same email address as your existing Zendesk login (support account). It’s essential that you use the same email address on our support center to ensure that your tickets stay attached to the same account.
Is there a way to create a backup to an FTP storage without using local storage?
4 comments
    Alexandros Rapsomanikis
    Has this changed with Plesk Obsidian? Perhaps using S3 Object Storage remote backup? Is there another way to overcome this issue despite option 1? Thank you for your time.
    Anton Maslov
    Yes, this is changed. It is not possible to avoid using at all, but to back up the server to cloud storage, you now need additional free disk space equal to the space occupied by two subscriptions, rather than the amount occupied by the entire server.
    Rens Houben
    Any two subscriptions, or the two largest ones?
    Anton Maslov (Edited )
    Good question Rens! Two largest ones. We updated text accordingly in article.
