MailEnable IMAP process consumes 100% CPU
Created:
2017-03-03 18:24:25 UTC
Modified:
2017-08-08 13:19:21 UTC
1
Have more questions?
Submit a request
  • Plesk for Windows
MailEnable IMAP process (MIEMAPS.exe) consumes 100% CPU.
In one of log files in MailEnable > Servers > hostname > Services and Connectors > IMAP > Logs > W3C can be found the following entry:
17-03-02 11:53:15 203.0.113.2 IMAP-IN example.com info 203.0.113.2 2200 AUTHENTICATE aW5mb0BhbHRjb25kZXNpZ24uY29t 2+NO+AUTHENTICATE+LOGIN+failed+-+Invalid+username+or+password. S00-WIN000 0 0 1532735
MailEnable of 7 major release or older uses on the server.
An old version of MailEnable.
Upgrade MailEnable to the latest version. For reference, see KB article How to upgrade MailEnable to a newer version
If after upgrade the issue persists, contact MailEnable support
