- Plesk for Windows
In what Plesk versions Node.js is available for installation?
What Node.js versions are available for installation in Plesk?
How to check Node.js version installed with Plesk via a command-line interface?
How to change Node.js version for a domain?
Node.js is available for installation starting from Plesk Onyx with any Plesk license edition.
Node.js versions that are available for installation via Plesk Installer:
- Node.js 10 (Currently Windows Server only)
- Node.js 9
- Node.js 8
- Node.js 6
To find out what Node.js versions are already installed on a Plesk server, run the command:
# plesk ext nodejs --versions
To find out which Node.js version is used by a domain application, run the command:
# plesk ext nodejs --get-version -domain example.com
In Plesk, go to Domains > example.com > Node.js > click on a version and select one from a drop-down menu.
10 comments
Hi! When can you enable NodeJS 10 on linux servers?
Hi @Luis Mendieta,
Currently, we don't have any particular ETA.
I'd recommend you following the article to receive notifications.
Be sure we'll update it as soon as NodeJS 10 for Linux servers is supported.
Please update to at least Node 10 ASAP - all the other node versions are insecure and end of live!
We can't really use Node on Linux this way.
@George Petrov
There is work in progress on adding the latest Node.js version to Plesk and to drop the ones that reached the end of life.
The article will be updated when any additional information is available.
ETA for this ?
Thanks
Hello,
Right now there is no exact ETA but as soon as there will be additional information, this article will be updated.
The information after new version being added will be also present at Plesk Change Log.
So the last NodeJS extension update is from 2017 ... are you serious? Do you know how much has changed since then in NodeJS and all old version are already deprecated and end of life...
This makes it impossible to run any decent NodeJS app on Plesk and make the support of it more a marketing joke then real production ready case.
Hello @George,
Thank you for the valuable feedback.
Indeed, current experience with Plesk for professional concentrated on Node.js is far from optimal.
According to the information I have, the current approach for updating supported Node.js versions is to be changed to be more up to date.
Please, stay tuned for this article updates and thank you for understanding.
Hello,
If you not see new version Node.JS (10,12) in Plesk , you must reinstall extension Node.JS after that all be fine!
Hello @Евгений,
Thank you for the comment.
It may be useful for other Pleskians!
