- Plesk Onyx 17.5 for Linux
Note: This article has the reference to the issue with the fix available:
- #PPP-31661 "Fixed the issue where, under certain circumstances, statistics counting could hang if qmail was used."
Fixed in:- Plesk Onyx 17.8 Preview 9 10 January 2018 (Linux)
- Plesk Onyx 17.8.11 Update 1 06 March 2018 (Linux)
Qmail is used as SMTP server.
Daily maintenance task hangs due to the following hung processes:
CONFIG_TEXT: root 14993 1 0 Aug24 ? 00:00:00 /usr/bin/perl /usr/sbin/sendmail -i – john.doe@example.com
root 14999 14993 0 Aug24 ? 00:00:00 _ /usr/sbin/sendmail.act -i – john.doe@example.com
popuser 15003 14999 0 Aug24 ? 00:00:00 _ /usr/sbin/sendmail.act -i – john.doe@example.com
popuser 15004 15003 0 Aug24 ? 00:00:00 _ /usr/local/psa/handlers/hooks/check-quota none root@plesk.example.com john.doe@example.comOR
CONFIG_TEXT: root 13975 0.0 0.0 28852 3180 ? Sep10 0:00 /usr/bin/perl /usr/sbin/sendmail -i – john.doe@example.com
root 13981 0.0 0.0 23868 1508 ? Sep10 0:00 _ /usr/sbin/sendmail.act -i – john.doe@example.com
popuser 13994 0.0 0.0 23868 1476 ? Sep10 0:00 _ /usr/sbin/sendmail.act -i – john.doe@example.com
popuser 13998 0.0 0.0 45900 2228 ? Sep10 0:00 _ /usr/local/psa/handlers/hooks/dk_sign signer root@plesk.example.com john.doe@example.comIf kill all
check-quota
ordk_sign
processes, execution of daily maintenance task continues. -
Also, the zombie process
logrotate
can be found as one of the child processes of the Plesk daily maintenance task:# ps auxwwf
root 4390 0.0 0.0 116880 712 ? Ss Mar16 0:07 crond
root 31308 0.0 0.0 173424 2188 ? S Mar18 0:00 \_ CROND
root 31309 0.0 0.0 106112 1052 ? Ss Mar18 0:00 | \_ /bin/bash -c [ ! -f /etc/cron.hourly/0anacron ] && run-parts /etc/cron.daily
root 31311 0.0 0.0 106112 1108 ? S Mar18 0:00 | \_ /bin/bash /usr/bin/run-parts /etc/cron.daily
root 31359 0.0 0.0 106116 1048 ? S Mar18 0:00 | \_ /bin/sh /etc/cron.daily/50plesk-daily
root 1634 0.0 0.0 76108 6232 ? S Mar18 0:04 | \_ /usr/local/psa/admin/bin/statistics_collector
root 6066 0.0 0.0 0 0 ? Z Mar18 0:03 | \_ [logrotate] <defunct> -
Scheduled task created using the steps below hangs with no notifications:
Log into Plesk as admin user.
Open the menu Profile & Preferences (My Profile in Power User view) and set email address (local mail account).
Create a task to run the command
/usr/local/psa/bin/sw-engine-pleskrun /usr/local/psa/admin/plib/DailyMaintainance/script.php -f ExecuteStatistics
and set the option Notify to Every time.
This is the Plesk bug PPP-31661, which was fixed in Plesk Onyx 17.8.11 Update 1.
Upgrade Plesk to Onyx 17.8.11.
Note: the workaround is applicable only to the operating systems based on RHEL 6 and 7 (CentOS, Red Hat Enterprise Linux, CloudLinux).
Check the currently used mail server in Tools & Settings > Mail Server Settings > Installed mail server.
Connect to the server using SSH.
Download a patch:
for Postfix (for OSes based on RHEL 7):
# wget https://support.plesk.com/hc/en-us/article_attachments/115002481014/postfix-sendmail-wrapper.tar.gz
for Qmail (for OSes based on RHEL 7):
# wget https://support.plesk.com/hc/en-us/article_attachments/115002475673/qmail-sendmail-wrapper.tar.gz
for Qmail (for OSes based on RHEL 6):
# wget https://support.plesk.com/hc/en-us/article_attachments/360003262673/qmail-sendmail-wrapper-pp17.5.3-cos6x64.tar.gz
Unpack the patched file (example for Postfix on OSes based on RHEL 7):
# tar -xzvf postfix-sendmail-wrapper.tar.gz
Backup the original file (example for Postfix on OSes based on RHEL 7):
# cp -ar /usr/lib64/plesk-9.0/postfix-sendmail-wrapper{,.orig}
Apply the patch (example for Postfix on OSes based on RHEL 7):
# cp -f postfix-sendmail-wrapper /usr/lib64/plesk-9.0/postfix-sendmail-wrapper
