[BUG] "Restrict the ability to follow symbolic links" option is not synced with Subsctiptions
4 comments
    Jonas Frey
    The referenced article is not accessabile as it throws a access denied message.
    I assume the following will do the job:
    mysql -u admin --password=`cat /etc/psa/.psa.shadow`  psa -e "UPDATE WebServerSettingsParameters SET value = 'true' WHERE name = 'restrictFollowSymLinks';"
    /usr/local/psa/admin/sbin/httpdmng --reconfigure-all
    Alisa Kasyanova
    @Jonas Frey
    Hi! Thank you for pointing that out, I have edited the article accordingly.
    Your query will set the FollowSymLinks option to TRUE for all domains as well :)
    Bob B
    Does step 3 have some syntax errors?
    Alisa Kasyanova
    @Bob B
    Yes, it should be (for i in `cat /root/list.txt`;), with quotes. They were lost somewhere :)
    I have updated the article accordingly, thank you for bringing our attention to it!
