- Plesk Onyx for Windows
1. SmarterStats is used for domain Web Statistics.
2. Web statistics page https://example.com/plesk-stat/webstat/
does not open or all buttons not operable.
is enabled in Home > Domains > example.com> Hosting Settings
SmarterStats does not support HTTPS. This is Plesk issue #PPPM-6921 which planned to be fixed in future product updates.
Solution
One of the following workarounds can be applied:
- Disable in Home > Domains > example.com> Hosting Settings .
- Use direct link to access web statistics:
http://example.com:9999
