How to enable leverage browser caching for nginx?
15 comments
    Atthawut Prathumrat
    nginx not ngnix :P
    Yulia Plokhotnikova
    @minzkung Thanks! I corrected it :)
    Horacio Stolovitzky
    Is possible to enable globally?
    Bulat Tsydenov
    @Horacio Stolovitzky, Hi! Please check this article again, it now contains the steps how to enable it globally.
    Kironet (Edited )
    Hi, after implementing this(not globally), my dynamic website stopped showing styles, images, etc.., and loading has time increased from 1.5s to +-10s. What can cause that?
    Thanhkieu2022
    Leverage Browser Caching you should use the plugin: Leverage Browser Caching
    link down: https://wordpress.org/plugins/leverage-browser-caching/
    I used for website: http://www.thuocmaxman.vn/ and get 99/100 points. only ... / google analytics.js (2 hours)
    Robert Asilbekov
    @Bogdan Dovgopol
    Instructions in the article cannot increase loading time.  It looks like some rewrite directives are missing.
    Ivan Postnikov
    @Thanhkieu2022
    Thank you for sharing this information. This is another way of enabling Leverage Browser Caching.
    Other Pleskians may find it useful.
    Sharul Hafiz
    Tried on Wordpress. Wordpress is not compatible with this. Will result in 404.
    Ivan Postnikov
    @Sharul
    For Wordpress try this plugin.
    Miomir Besarabic
    @Thanhkieu2022, @Ivan Postnikov
    This plugin is only for Apache but this is article about leverage browser caching for nginx. Please don't post wrong information.
    Ivan Postnikov
    @Miomir
    Thank you for the notice about the plugin.
    I have double checked it. It is applicable for Apache only.
    Miomir Besarabic (Edited )
    This works if you add under Apache & nginx Settings in Additional nginx directives:
    Add Expires Headers
    location ~* \.(jpg|jpeg|png|gif|ico|css|js)$ {
    expires 365d;
    location ~* \.(pdf|html|swf)$ {
    expires 90d;
    Add Cache-Control Headers
    expires 90d;
    add_header Cache-Control "public, no-transform";
    I have tested with Wordpress and it works great. If Serve static files directly by nginx option is enabled in Domains > example.com > Apache & nginx Settings, it is required to disable it.
    Pingdom and GTmetrix honor this.
    Markus Wernecke
    Thank you very much for all amazing and helpful articles.
    I use nginx only in subscription settings (service plans)
    Please, please, for all those who use this environment it would be the greatest gift if you could write also support articles for using
    only nginx
    Wish you all the best. PLESK is awesome...
    Ivan Postnikov
    Hello @Markus!
    Thank you for the feedback.
    Sure, new articles are driven by demand. If there will be questions or issues regarding using Nginx only, the corresponding articles will be created.
