How to enable leverage browser caching for nginx?
48 comments
    Atthawut Prathumrat
    nginx not ngnix :P
    1
    Yulia Plokhotnikova
    @minzkung Thanks! I corrected it :)
    Horacio Stolovitzky
    Is possible to enable globally?
    Bulat Tsydenov
    @Horacio Stolovitzky, Hi! Please check this article again, it now contains the steps how to enable it globally.
    1
    Unknown User (Edited )
    Hi, after implementing this(not globally), my dynamic website stopped showing styles, images, etc.., and loading has time increased from 1.5s to +-10s. What can cause that?
    Thanhkieu2022
    Leverage Browser Caching you should use the plugin: Leverage Browser Caching
    link down: https://wordpress.org/plugins/leverage-browser-caching/
    I used for website: http://www.thuocmaxman.vn/ and get 99/100 points. only ... / google analytics.js (2 hours)
    -1
    Robert Asilbekov
    @Bogdan Dovgopol
    Instructions in the article cannot increase loading time.  It looks like some rewrite directives are missing.
    Ivan Postnikov
    @Thanhkieu2022
    Thank you for sharing this information. This is another way of enabling Leverage Browser Caching.
    Other Pleskians may find it useful.
    Sharul Hafiz
    Tried on Wordpress. Wordpress is not compatible with this. Will result in 404.
    Ivan Postnikov
    @Sharul
    For Wordpress try this plugin.
    -1
    Miomir Besarabic
    @Thanhkieu2022, @Ivan Postnikov
    This plugin is only for Apache but this is article about leverage browser caching for nginx. Please don't post wrong information.
    Ivan Postnikov
    @Miomir
    Thank you for the notice about the plugin.
    I have double checked it. It is applicable for Apache only.
    Miomir Besarabic (Edited )
    This works if you add under Apache & nginx Settings in Additional nginx directives:
    Add Expires Headers
    location ~* \.(jpg|jpeg|png|gif|ico|css|js)$ {
    expires 365d;
    location ~* \.(pdf|html|swf)$ {
    expires 90d;
    Add Cache-Control Headers
    expires 90d;
    add_header Cache-Control "public, no-transform";
    I have tested with Wordpress and it works great. If Serve static files directly by nginx option is enabled in Domains > example.com > Apache & nginx Settings, it is required to disable it.
    Pingdom and GTmetrix honor this.
    Markus
    Thank you very much for all amazing and helpful articles.
    I use nginx only in subscription settings (service plans)
    Please, please, for all those who use this environment it would be the greatest gift if you could write also support articles for using
    only nginx
    Wish you all the best. PLESK is awesome...
    1
    Ivan Postnikov
    Hello @Markus!
    Thank you for the feedback.
    Sure, new articles are driven by demand. If there will be questions or issues regarding using Nginx only, the corresponding articles will be created.
    1
    Peter Shaw (Edited )
    This works well for my WordPress installation and sets the expires headers that I'm after, however URLs for "virtual files" that don't physically exist on the server in WordPress [such as robots.txt] now return a 404 page. I believe this is because no further Nginx processing takes place after the headers are set with the location directive.
    Much advice on the internet suggests the use of try_files directive but the solution I am looking for is more along the lines of "for any file that doesn't physically exist on the server, ask Apache for it". Is something along these lines possible?
    I give robots.txt as an example but the solution needs to be generic so it can also handle secure files that are stored outside of the webroot with rewriting carried out by Apache.
    ***EDIT***
    From digging into the NGINX docs I see that what I actually want is a nested location directive - the initial block is lifted from the default nginx config within plesk, the second block adds expires headers to relevant files:
    location / {
        proxy_pass http://77.68.75.xxx:7080;
        proxy_set_header Host             $host;
        proxy_set_header X-Real-IP        $remote_addr;
        proxy_set_header X-Forwarded-For  $proxy_add_x_forwarded_for;
        proxy_set_header X-Accel-Internal /internal-nginx-static-location;
        access_log off;
        location ~* \.(js|jpg|jpeg|gif|png|css|tgz|gz|rar|bz2|doc|pdf|ppt|tar|wav|bmp|rtf|swf|ico|flv|woff|woff2|svg|ttf)$ {
            etag on;
            if_modified_since exact;
            add_header Pragma "public";
            add_header Cache-Control "max-age=1209600, public";
    I can test the above by manually editing the /vhosts/system/[domain]/conf/nginx.conf file and restarting nginx systemctl restart nginx.
    This directive can't be applied using the Additional Nginx Directives option within plesk as a location directive for / already exists in the template, so any changes will be overwritten each time nginx.conf is recreated. How/where can I amend the plesk nginx template so that the individual vhost conf files that are generated use this modified directive?
    Alexandr Redikultsev
    Hello,  @Peter Shaw.
    Please try combining the directives with the ones specified in the following knowledge base article:
    A WordPress website on a Plesk server shows "404 Not Found" on all pages except index.php, when running on FPM by nginx
    Lenusch
    Any disadvantages to enable this for all Customers?
    Does it make more CPU / RAM Load?
    Robert Asilbekov
    @Lenor
    No
    It might affect some customers websites. For example, if the content was changed but the web browser may keep using the old version from the local cache as the content is yet to be expired.
    Tomasz Paluszkiewicz
    in your article about enabling gzip compression, you advise to create
    /etc/nginx/conf.d/gzip.conf
    (which will be automatically picked up because of wildard include in nginx.conf)
    but in this article you advise creating
    /etc/nginx/conf.d/expires.global
    and then adding include rule inside
    /usr/local/psa/admin/conf/templates/default/domain/nginxDomainVirtualHost.php
    why the difference? what are the (dis-)advantages of one approach over the other?
    Robert Asilbekov
    @Tomasz Paluszkiewicz
    Because "location" directive is not allowed in "http" context.
    @Robert Asilbekov
    but then, gzip compression could also be applied the same way as expiry rules, right?
    Robert Asilbekov
    Correct, gzip compression could be also enabled this way. But it is better to enable gzip globally in "http" context and later it can be turned off for a particular subscription.
    Because gzip contexts are: httpserverlocationif in location
    Alisa Kasyanova
    @Peter Shaw
    Hi! Please refer to our documentation here. You can edit nginx template, so the directive will be applied to all domains.
    Thanks @Alisa Kasyanova,
    Created /usr/local/psa/admin/conf/templates/custom/domain/service/proxy.php and copied in the corresponding file from /templates/default. Added the following block below 'access_log off;':
    access_log off;
    <?php /** add expires headers where required. **/ ?>
                    etag on;
                    add_header Cache-Control "max-age=86400, public";
    Regenerate nginx configuration files with /usr/local/psa/admin/bin/httpdmng --reconfigure-all
    EDIT ***
    The above is along the right lines but it is not the correct solution to the issue as ther resulting nginx.conf file doesn't give the desired headers for all requests - some requests for virtual files are not passed on when they should be.
    Alisa Kasyanova
    @Peter Shaw
    I suppose it is because the resulting nginx configuration file for a domain (you can check any, say, /etc/nginx/plesk.conf.d/vhosts/example.com.conf) has a location directive inside another location directive.
    Try to add lines starting from "location..." to /usr/local/psa/admin/conf/templates/custom/domain/nginxDomainVirtualHost.php . For example, before "<?php if (!$VAR->domain->physicalHosting->proxySettings['nginxTransparentMode'] " and reconfigure the files. Then check the /etc/nginx/plesk.conf.d/vhosts/example.com.conf) again: it should have the "location..." as a separate section.
    Hope it helps!
    Cirrus (Edited )
    I think this article should be listed in Additional Information here.
    Additional nginx directives/Leverage browser caching are ignored for a WordPress website
    https://support.plesk.com/hc/en-us/articles/360014674853
    (via https://talk.plesk.com/threads/browser-caching-suddenly-disabled.350651)
    Denis Bykov
    @Cirrus Tecnologia
    Thank you for the feedback!
    Indeed, this link will be useful here. I've updated the article accordingly.
    Taha AK (Edited )
    Leverage doesn't have browser caching
    Help pls website: https://gokkusagikoltukyikama.com
    NGINX
    location ~* .(js|jpg|jpeg|gif|png|css|tgz|gz|rar|bz2|doc|pdf|ppt|tar|wav|bmp|rtf|swf|ico|flv|txt|woff|woff2|svg)$ {
    expires max;
    add_header Cache-Control "public";
    Daria Gavrilova
    Hello @Taha AK,
    As I can see from the provided screenshot the leverage browser caching does not work for Google Analytics only, as it does not host on your server.
    If you would like to get rid of this warning, I recommend you to check the possibility of hosting Google analytics.js file locally.
    For more information on this matter, please contact Google Analytics Support or search for possible solutions around the Internet.
