How to connect WordPress to the memcached installed in Docker container?
4 comments
    Christopher-James Sheppard
    Hi, ive installled memcached and is running but in W3TC all i get is the warning
    The following memcached servers are not responding or not running:
    • Object Cache: 127.0.0.1:11211.
    • Page Cache: 127.0.0.1:11211.
    This message will automatically disappear once the issue is resolved.
    Alexandr Redikultsev
    Hello, @Christopher-James Sheppard.
    Make sure that both commands below are working properly:
    # { echo "stats"; sleep 1; } | telnet localhost 11211 | grep "get_"
    # { echo "stats"; sleep 1; } | telnet 127.0.0.1 11211 | grep "get_"
    Dennis Am
    Please note that creating a docker container will open its port (in this case 11211) to the internet, as Plesk Firewall doesn't work for Docker (see https://support.plesk.com/hc/en-us/articles/360011626333-Plesk-Firewall-deny-rules-do-not-block-connections-to-Docker-container). Running a simple iptables command ensures that the port is closed for the internet so it can't be abused. Could you please consider adding this information to the article for improved security?
    Daria Gavrilova
    Hello @Dennis Am,
    Thank you for your input.
    The article will be modified accordingly.
