How to reset activation of CloudFlare extention?
2 comments
    Héctor Sanmej
    This option not exists in Spanish version... And I need to reset the cloudflare configuration because some domains AREN'T ADDED in my cloudflare account... and Plesk creates the CNAME to CLOUDFLARE and the site make a loop redirection... How can I solve this?
    Daria Gavrilova
    Hello @Héctor Sanmej,
    Thank you for your questions.
    I double checked CloudFlare extension and found that Click here to reset this page link exists in Spanish version.
    It can be found at Plesk > ServerShield de Cloudflare > Configuraciones > Haga clic aquí para reinicializar esta página
    As for the loop redirection:
    The most possible cause of such behavior is that SSL settings are set as " Flexible " in CloudFlare's account.
    To solve the issue, please check the following article: Domain gets ERR_TOO_MANY_REDIRECTS error with enabled CloudFlare
