- Plesk for Windows
The https://intodns.com/ shows the following error for a domain:
PLESK_INFO: Reverse MX A records (PTR) ERROR: No reverse DNS (PTR) entries. The problem MX records are:
1.2.3.4.in-addr.arpa -> no reverse (PTR) detected
You should contact your ISP and ask him to add a PTR record for your ips
Or
The http://leafdns.com/ shows the following error for a domain:
PLESK_INFO: None of your MX record IP addresses have corresponding reverse DNS entries (PTR records). If these MX records are used to send outgoing mail this will cause them to trip anti spam filters. Many SMTP servers will not accept mail from an IP with no reverse DNS.
Or
Mail from the domain bounced by remote mail server with error:
PLESK_INFO: host mail.receiver.example.com[203.0.113.2] said: 550
inconsistent or no DNS PTR record for 203.0.113.3 (see RFC 1912 2.1) (in reply to RCPT TO command)
DNS misconfiguration.
If Plesk DNS server is used, add PTR record for the domain using KB article 213934905.
In case an external DNS server is used, it is required to contact Internet Service Provider (ISP) in order to add appropriate PTR records.
Note: it is required to wait for the DNS propagation period. It may take up 48 hours, but mostly faster.
