Unable to locate src files required for recompiling of apache in order to host more then 900 domains
Created:
2017-08-10 23:37:25 UTC
Modified:
2017-08-10 23:38:14 UTC
Have more questions?
Submit a request
Unable to locate src files required for recompiling of apache in order to host more then 900 domains The recommendation to recompile apache was taken from this article:
How to recompile Apache, PHP, and IMAP with increased value of file descriptors larger than FD_SETSIZE (1024) on a RedHat-like system
Modern Plesk versions include modern Apache version, so it is not required to recompile apache in order to host more then 900 sites. It already allows doing so
If a lot number of domains should be hosted on a Plesk server, hardware requirements should be met according to the number of sites. For example, we recommend having 1GB of RAM for every 40-50 websites.
