Plesk for Windows
kb: how-to
ABT: Group A
- Plesk for Windows
How to adjust an IIS application pool in Plesk?
There are no general recommendations as it directly depends on server configuration. However, it is possible to limit a number of CPU resources that the IIS application pool can use.
Go to Domains > example.com > Dedicated IIS Application Pool for Website.
Set Maximum CPU usage (%) limit.
Select Limit action that IIS performs when a worker process exceeds the configured maximum CPU usage.
Set Limit interval (minutes) to specify the reset period for monitoring of CPU usage on an application pool at option.
2 comments
Hello,
any CPU, memory, recycling time intervals, etc. recommendations settings for shared hosting servers? Thanks,
Regards,
Hello,
We do not have recommendations other than described in server software requirements:
https://docs.plesk.com/release-notes/obsidian/hardware-requirements/
The limits should be adjusted based on your personal needs: how many websites, how heavy they are loaded etc.
