Plesk for Windows
kb: technical
ABT: Group A
- Plesk for Windows
- Servers RDP over Plesk in Tools & Setting > Remote Desktop doesn't work: blank page is shown.
- Windows Server 2016 is used on the Plesk server.
ActiveX support is not configured on the client computer or on the server.
On the client computer use any browser with the ActiveX support, e.g. IE 11 or IE 10 or 9 and lower or Chrome with the IETab add-on.
Set sufficient ActiveX permissions for the client computer in Internet Explorer > Settings > Internet options > Security ( https://support.microsoft.com/en-us/help/17469/ )
Log in to Plesk server using RDP.
Click on Start button, type Regedit and press Enter.
Change
SecurityLayer
andUserAuthentication
to ahexadecimal
zero inHKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Terminal Server\WinStations\RDP-Tcp
and reboot the server.
2 comments
Thank You!! Been looking around for a few days for a fix.
@ecabrera81
Hi!
Thank you for the feedback.
Glad to know that the article helped to resolve your issue!
