If you had already registered your account at Plesk 360 (formerly known as My Plesk) please use one for login. Otherwise please re-register it using the same email address as your existing Zendesk login (support account). It’s essential that you use the same email address on our support center to ensure that your tickets stay attached to the same account.
Is it possible to export DNS zone data for a domain using Plesk?
6 comments
    Don Duke
    -bash-4.2$ /usr/local/psa/bin/dns --info example.com > dom_dns.txt
    Could not open Repository at "/etc/sw/keys": Cannot open file: /etc/sw/keys/info
    -bash-4.2$
    What now? :/
    Lev Iurev
    Hi @Don Duke
    looks like insufficient permissions for user that tries to execute the command. that is described here
    Hank
    The second command includes a specific domain name and only gives me data for that domain. How can I put a wildcard or variable in there?
    Hank
    Ok I replaced it with $i
    # for i in `mysql -uadmin -p\`cat /etc/psa/.psa.shadow\` psa -Ns -e "select name from domains"`; do /usr/local/psa/bin/dns --info $i; done > dom_dns.txt
    Ivan Postnikov
    Hello @Hank,
    Thank you for the notice.
    The article will be updated soon.
    David Matney
    Would be nice to be able to import a zone also.
