Starting on October 19, 2021, we will enable single-sign-on for our Plesk Support Center to provide a seamless login/account experience. This implies that you’ll be able to use a single account across any of our web-facing properties.
To be prepared for this change and to avoid the need to register during your next ticket submission after the change, we encourage you to create an account here before October 19 using the same email address as your current Zendesk login (support account). It’s essential that you use the same email address on our support center to ensure that your tickets stay attached to the same account. You will continue to use ZenDesk authentication until we switch over to single-sign-on on October 19th.
Is it possible to export DNS zone data for a domain using Plesk?
6 comments
    Don Duke
    -bash-4.2$ /usr/local/psa/bin/dns --info example.com > dom_dns.txt
    Could not open Repository at "/etc/sw/keys": Cannot open file: /etc/sw/keys/info
    -bash-4.2$
    What now? :/
    Lev Iurev
    Hi @Don Duke
    looks like insufficient permissions for user that tries to execute the command. that is described here
    Hank
    The second command includes a specific domain name and only gives me data for that domain. How can I put a wildcard or variable in there?
    Hank
    Ok I replaced it with $i
    # for i in `mysql -uadmin -p\`cat /etc/psa/.psa.shadow\` psa -Ns -e "select name from domains"`; do /usr/local/psa/bin/dns --info $i; done > dom_dns.txt
    Ivan Postnikov
    Hello @Hank,
    Thank you for the notice.
    The article will be updated soon.
    David Matney
    Would be nice to be able to import a zone also.
