Is it possible to enable auto-reply in the Horde interface in Plesk?
2 comments
    Gilberto Greppi
    Also through Roundcube/Webmail is not possible?
    Can I enable and use Sieve through Webmail?
    Alisa Kasyanova
    @Gilberto Greppi
    Hi! You may enable auto-reply in RoundCube, it is needed to create it in Settings > Filters.
    You can also use Sieve if your IMAP/POP3 server is Dovecot (it is also done in Settings > Filters).
