- Plesk Onyx for Linux
- Attached images are not shown in RoundCube;
- Images could be downloaded by pressing the Download button. However, they could not be opened on the filesystem;
When trying to view an image with enabled firebug (F12 button in a browser) the following errors appear:
Resource interpreted as Document but transferred with MIME type image
or
Image cannot be displayed because it contains errors
- Hexes of the sent and downloaded images differs: the downloaded one has some additional bytes at the beginning of the file:
# xdd sent_file
0000000: 2f75 7372 2f6c 6962 3634 2f6c 6962 6462# xdd downloaded_file
0000000: 6173 6461 730a 6461 7378 6361 730a 6661
0000010: 7364 660a 2f75 7372 2f6c 6962 3634 2f6c
Syntax error in one of the RoundCube's scripts.
Check all customized ".php" scripts in
/usr/share/psa-roundcube/
. If it is possible, compare the installed RoundCube with the test one. Try to find additional closing tags, carriage returns etc.
