- Plesk for Windows
Websites fail to load with the following error:
CONFIG_TEXT: HTTP Error 401.2 - Unauthorized
You are not authorized to view this page due to invalid authentication headers.
Module
UrlAuthorizationModule
Notification
AuthorizeRequest
Handler
ExtensionlessUrlHandler-Integrated-4.0
Error Code
0x80070005
URL Authorization is enabled in Add Features and Roles Wizard > Web Server (IIS) > Security .
By default, there are no rules installed for this module in IIS Manager > Server > Authorization Rules that cause such an error.
Connect to the server using RDP ;
Remove module URL Authorization from Add Features and Roles Wizard > Web Server (IIS) > Security.
Reboot the server.
OR
Open IIS Manager > Server > Authorization Rules and add a rule Allow for All users .
