Uploading of big file on websites hosted in Plesk fail: client intended to send too large body
7 comments
    Francesc Benavent
    In Plesk Obsidian 18.0.29, the default value for nginxClientMaxBodySize is :
    [webserver] nginxClientMaxBodySize 128m
    as stated by the "panel.ini editor" extension.
    Ivan Postnikov
    Hello Francesc Benavent
    You're right, I will adjust the article.
    Michel vd Lingen
    Didn't help. Still the same issue.
    Tobias Maffert
    same here. Still the same issue :( Any ideas? - Plesk Obsidian Version 18.0.36
    Tobias Maffert
    I have probably found the problem. If one carries under "/var/www/vhosts/system/meinedomain.de/conf/nginx.conf" at location / also again client_max_body_size 500M; and restart nginx, it works. Can this (location area) be set via the Plesk web interface?
    Andy Herzig
    After setting new value in panel.ini, one should execute
    # plesk sbin httpdmng --reconfigure-all
    or
    # plesk repair web -domains-only
    instead of
    # plesk repair web -server
    actually, isn't it?
    Benjamin Weßel
    Hello Andy Herzig,
    Thank you for pointing us to that issue in the article.
    It is now updated with the correct information.
