Unable to unistall Prestashop: Installation requirements are not met
Created:
2017-07-30 00:58:23 UTC
Modified:
2017-08-08 13:09:38 UTC
1
Have more questions?
Submit a request
  • Unable to install Prestashop:
    PLESK_ERROR:Error: Unable to install the app because its installation requirements are not met. Contact your hosting provider to resolve this problem.
    PHP extension
    The 'mcrypt' extension was not found.
    PHP extension
    The 'mysqlnd' extension was not found.
  • The PHP verion 5.4 is in use.
Cuase
These extensions are not available in the PHP version 5.4.
Switch the PHP version in PHP Settings menu to 5.6 or higher in Domains > example.com > PHP Settings.
