Confusing warning for a domain migrated from cPanel
Created:
2017-01-27 05:44:14 UTC
Modified:
2017-08-08 13:22:21 UTC
Have more questions?
Submit a request
  • Plesk 12.0 for Linux
There is a warning in migration report for a domain migrated from cPanel:
Warning:
Couldn't get 'cgi_bin_mode' attribute for domain where cgi-bin dir is '' and docroot dir is '/home/example/public_html'. Domain will be migrated in that way as if its cgi-bin directory was located under docroot. "
Domain is migrated with Plesk Migration & Transfer Manager
Inconsistency in cPanel database
If domain's cgi-bin directory is inside of document root directory on the source server it will be migrated as is and this warning can be safely ignored.
If there is some customization on the source, content of cgi-bin directory should be transferred to Plesk server manually for affected domains.
