How to enable support for Python script engine in Plesk for Windows?
Created:
2017-07-29 07:40:48 UTC
Modified:
2017-08-16 16:38:00 UTC
Have more questions?
Submit a request
  • Plesk for Windows
Since Plesk 12.5 Python script engine is not supported and there is no Python support option under Subscriptions > example.com > Hosting Settings . As a workaround, install Python support manually following these steps:
  1. Log into the server using RDP .
  2. Download 32-bit version of Python from autoinstall-win.pp.parallels.com or from activestate.com.
  3. Install it to the %plesk_bin%\Additional folder.
  4. Add "Read & Execute", "List folder contents" and "Read" permissions for the psacln and psaadm users to the %plesk_bin%\Additional\Python(*) folder, where (*) - Python version.
  5. Check that Python support option is enabled in the service plan and for the domain: Service Plans > [Service plan name] > Hosting parameters Subscriptions > example.com > Hosting Settings
Use this article to confirm that Python is enabled and working for the domain.
