How to limit download speed for a website's files in Plesk?
4 comments
    Gonzalo Besoain
    Thanks for the article, but It doesn't work in my case.
    Is there any other pre-requisite beside to disable Nginx?
    Konstantin Annikov
    @Gonzalo,
    Thank you for the question. We have reworked the article to be able to do the same with nginx directives.
    Gonzalo Besoain (Edited )
    Thank you very much Konstantin!
    Another question, how can this be implemented in a subdomain? I've tried but it doesn't seems to work (Apache) or throw me an error in nginx
    If I enable nginx and made the config changes in the subdomain config, Plesk don't allow me and gave me this error...
    ....New configuration files for the Apache web server were not created due to the errors in configuration templates: nginx: [emerg] duplicate location "/" in /var/www/vhosts/system/subdomain.domain.com
    My config in the subdomain was:
    location /{
        limit_rate 350k;
    Konstantin Annikov
    @Gonzalo,
    If it is needed to add limit_rate to "/" location, you should not define the location, as it is already defined.
    So, you can just type in
     limit_rate 350k;
    Into Additional nginx directives
