How to secure FTP in Plesk for Linux?
Created:
2017-01-23 23:04:07 UTC
Modified:
2017-08-08 13:09:55 UTC
Have more questions?
Submit a request
How to configure secure FTP in Plesk for Linux?
FTP over SSL can be activated with following steps:
  1. Allow using custom FTPS settings per IP address in Tools & Settings > Security Policy
  2. Configure FTPS in Tools & Settings > IP addresses > Allow both secure FTPS and non-secure FTP connections.
Made sure that the following lines is present in /etc/proftpd.conf:
<IfModule mod_tls.c>
# common settings for all virtual hosts
TLSEngine on
TLSRequired off
TLSLog /var/log/plesk/ftp_tls.log
TLSRSACertificateFile /usr/local/psa/admin/conf/httpsd.pem
TLSRSACertificateKeyFile /usr/local/psa/admin/conf/httpsd.pem
# Authenticate clients that want to use FTP over TLS?
TLSVerifyClient off
# Allow SSL/TLS renegotiations when the client requests them, but
# do not force the renegotations. Some clients do not support
# SSL/TLS renegotiations; when mod_tls forces a renegotiation, these
# clients will close the data connection, or there will be a timeout
# on an idle data connection.
TLSRenegotiate none
# As of ProFTPD 1.3.3rc1, mod_tls only accepts SSL/TLS data connections
# that reuse the SSL session of the control connection, as a security measure.
TLSOptions NoSessionReuseRequired
</IfModule>
