Plesk shows error: Call to undefined method pm_Context::getBuyUrl() or Call to undefined method pm_Domain::getIpAddresses()
6 comments
    Stefan Warnat
    Hy,
    I get exactly this problem, too. 4 of my Domains from ~90 show this error during renewal.
    After really intensive searching I found the reason and I'm absolutely sure this also is the problem in your case:
    Some weeks/months ago, LetsEncrypt started to use IPv6 for validation.
    Problem was, the IPv6 Address I configured in DNS Server doesn't match with IPv6 address from Plesk.
    After I correct DNS server, this problem was gone.
    But on long term we really should plan to update to Onyx. There are some interesting features ;)
    Regards,
    Stefn
    Alexandr Tumanov
    @Xaoc
    This function was implemented in Plesk Onyx only and the action you are trying to do is not compatible with the current version. I suppose that you are trying to install an unsupported extension. Please let me know if I'm wrong.
    Marc van Bekkum
    I disaggree, Lets enrypt works fine on allmost all my domains (30+ domains) on Plesk 12.5. I only had this problem on one domain. I'm still figuring out why... :(
    Lev Iurev
    @Stefan  yep, Plesk Onyx is cool)
    Permanently Deleted User
    Seriously??? Isnt there a workaround? I would have to redo the custom nginx configs...
    Konstantin Annikov (Edited )
    Hi Marc,
    What error appears in web interface? Maybe you can provide a screenshot?
    I am asking as there is possibility that the error appeared on your server is not exact error from this article.
